Currently Inventor parts can be opened in Creo Parametric and all the standard properties are converted in parameters (and saved in the .creo file).
Inventor doesn't use the same naming as Creo , this leads to some missing parameters.
When creating a drawing with an assembly consisting out of Creo and inventor parts, and creating a BOM , you'll notice that some of the parts don't show up in the BOM-table.
This occurs due to the parameters missing that creo uses to create the BOM.
all imported inventor properties
