Be possible to create curves on bodies, quilts, surfaces, with an angle to a specific direction.
See from solidedge:
https://www.youtube.com/watch?v=pPCrpZyi1RE
From NX:
https://www.youtube.com/watch?v=oEeNlSsp5e8
In both videos, the isocline curve is applied to a sphere. The particular case of a sphere is simple to create those curves. But for a complex part like this, is not that simple! Specially with the variable radius.
