Isometric dimensioning Creo Elements Direct Modeling
This is an enhancement request regarding dimensioning isometric views in Creo elements direct modelling.
The problem is that you are not able to smart draw dimensions that relate to the drawing on an Isometric view. When you dimension an edge on the isometric view it shows the actual length of the line on the view and not the dimension relative to the part. Below is a screen shot example:
When creating drawings it would be more flexible to have the option of showing a dimension in the isometric view. It can help isolate an idea or put a new perspective into the drawing.
Currently because there is no option to have the true length of the part displayed. The dimension has to be manually inserted which does take longer.
Creo Parametric does not also include this feature. I can understand because traditionally engineering drawings are best presented in a 2D format where dimensions are easier to read. The idea of having this feature enhancement has arisen from a number of our clients asking why this is not possible. The point had been raised in 2010 as an SPR but recently it has been advised to log as an enhancement request.
This feature could introduce a new level of engineering drawings where you can freely express dimensions on any orientation.
Thank you for taking this into consideration.
Regards
Harry Naden-Caldwell
High Peak Systems
7 Comments
MartinSpeakman
1-Newbie
Our customers expect this type of dimensioning to be available as it is a clearer mechanism to convey key information regarding the product to non technical personnel.
FriedhelmK
If i need this kind of view i do this in Modeling with Anno-3D.
In addition, you can then use the dimensions to change the model.
MartinSpeakman
1-Newbie
We know all about the 3D dimension which is great but we want to include this on a drawing with the orthognal views.
GerardLeclercq
This is a need for dimensionning isometric drawings of piping as well.
PeterKehoe
I don't like dimensioning like this because it isn't always clear the intent of the measurement direction, and hence the dimension value.
whofer
8-Gravel
PTCModerator
Emeritus
