It is currently not possible to create dimensions on open B-splines in Annotation.
It is, however, possible to create 3D-dimensions on open B-splines in Modeling, which can then be transfered to Annotation via a documentation plane. Unfortunately this method does not allow you to transfer the center lines.
It should be made possible to create dimensions on open B-splines in Annotation.
