It should be made possible to wrap a spline curve on a cylinder onto a work plane
It is possible to wrap a spline curve that is on a work plane onto a cylindrical surface using the function "Wrap on Surf".
However, it is currently not possible to go the other way and to wrap a spline curve that lies on a cylindrical surface back onto a work plane.
This should be made possible.
Workaround: None found. Attempts to use sheet metal functions were unsuccessful.
1 Comment
olivierlp
Community Manager
Status changed to: Archived
