It should be possible to copy multiple workplanes in one step
0 Kudos
It should be possible to copy multiple workplanes or WP - sets in one step.  At the moment you get the error message : Single selection is required .
A possible workaround for you would be to create an assembly and put the workplanes in the assembly.  Then copy that assembly (be sure to copy all levels) and move it.
  You can then remove the workplanes from the assemblies, but you will have to rename them due to the naming conflict.
But this workaround needs to many steps . Creating assembly, renaming the workplanes ... .
It  is possible to copy several  parts or assemblies, because of that  it should be possible with workplanes and WP Sets , too.
1 Comment
olivierlp
Community Manager
Status changed to: Archived
