The PTC Community email address has changed to community-mailer@ptc.com. Learn more.
It would be nice to insert jog on a radius, diameter and chamfer dimensions, so dimension is link to model.
It would be nice to insert jog on a radius, diameter and chamfer dimensions, so dimension is link to model. There is somewhat a work around, which is to create a note, but there is a bug. There are other things I can do, but it is a hassle. Please also see my post "It would be nice to insert jog on a radius dimension, so dimension is link to model."in PTC community.
2 Comments
ScottMorris
I guess its been a long time since I've created drawings in Creo, but I am shocked you cannot add a jog to a Radius, Diameter or Chamfer dimension. I understand the workaround of creating a note, but that's not acceptable. If you can put a jog on other items, why can't you put it on these dimension types? I would push this request to allow jogs on all dimension and callout types that are not supported.
olivierlp
Community Manager
Status changed to: Archived
