At the moment the Import Type to choose between Part OR Assembly is greyed out when import JT file in Creo Parametric.
We want to be able to choose the import type between Part OR Assembly when importing a JT file in Creo Parametric as soon as possible.
See article:
https://www.ptc.com/en/support/article/CS295442?&language=en
