Keep the solution
0 Kudos
Keep the solution
If you don't ask for it, you don't get it which means a re-run.
Simulate ne Mechanica was coded to 'throw the solution away'; a decision to do this decades ago presumably driven by prehistoric hardware capability. We now have fast and cavernous machines.
All that is stored is the calculated quantities at nodes plus the requested measurements. The 'solution', the bit that takes time to calculate is discarded.
If one forgets to ask for a measure then unless it can be retrieved by inference or post processor a re-run is required.
If one makes a mistake in measure creation e.g. asking for x component rather than y (we are all human) then a re-run is required.
1 Comment
ToddKraft
Status changed to: No Plans to Implement
Thanks for the idea.  This has been considered but it is a very significant development project to enable this and we currently don't plan to implement this.
Todd Kraft
Creo Product Manager
