In Microsoft Office applications, if I make a selection, for example, if I change the font size of a word, I can select another word and press F4 and it will repeat the font size setting for the new word, et cetra ad nauseam.
In WF4, CP2 or whatever, I sometimes want to do the samething rpeatedly, but I have to click the same sequence of selections each time. For example, I might want to change the balloon type of several BOM balloons from with quantity to without quantity, or I might want to make a number of dimensions basic.
If I were able to select the next candidate balloon or dimension and press F4, it would save quite a lot of mouse clicks over the course of a day.
The ribbon UI seems to be an attempt to mimic the Microsoft Office UI, so let's take it a bit further and mimic some of the good bits as well.
I apologise if this is already implemented in Creo 2.0.
We're way behind the times in Somerset! WF4/Ilink 3.4.
Please vote up, even if you only think it is not a bad idea.
John
