Hoses are generally used to convey fluids when a tube cannot be used because there is motion or vibration between the connection points. It would be awesome if Creo would have a tool to simulate the behavior/motion of a hose on a pivot or slider joint mechanism and analyze/optimize the hose length and slack to be able to meet all the positions in the mechanism and show the stress concentrations and bend violations or failures.
This tool could also be used for cabling simulation.
