Security Alert Log4j Security Vulnerability. Click here to know more.
Layer status of view should not change when view layer is selected.
When selecting the layer tree of an individual view, all of the layers are turned on.  I would prefer that the layer status stays the same as the drawing layer status until I unhide a layer.  It should also remain drawing dependent until a change is made.
I mostly modify the layer status of a view to show one or two items in that view such as a cosmetic sketch.  When everything is reset, the drawing layer status, that has already been set as needed is lost.
2 Comments
dgschaefer
Absolutely yes!  On larger assys or complex parts, when all the layers get reset there's a significant delay while everything gets automatically displayed.  Then, once I re-hide the layers I wanted hidden (usually most of them), the display doesn't automatically update.  I have to go in a manually update it, again with a significant delay on complex parts.  A ridiculous workflow.
olivierlp
Community Manager
Status changed to: Archived
