Layer status of view should not change when view layer is selected.
When selecting the layer tree of an individual view, all of the layers are turned on.  I would prefer that the layer status stays the same as the drawing layer status until I unhide a layer.  It should also remain drawing dependent until a change is made.
I mostly modify the layer status of a view to show one or two items in that view such as a cosmetic sketch.  When everything is reset, the drawing layer status, that has already been set as needed is lost.
2 Comments
dgschaefer
Absolutely yes!  On larger assys or complex parts, when all the layers get reset there's a significant delay while everything gets automatically displayed.  Then, once I re-hide the layers I wanted hidden (usually most of them), the display doesn't automatically update.  I have to go in a manually update it, again with a significant delay on complex parts.  A ridiculous workflow.
olivierlp
Community Manager
Status changed to: Archived
