Why does your model tree "hide" command works as it supposed to - i.e. hides entities instantly, while layer one does not? Is there any reason at all for when you select "hide" or "unhide" for a layer, it does not do that untill you click in a modeling window? Just pure commons sense and a click-saver, please fix, thank you.
