Legend levels, define in definition window
Creo simulate, pro/mechanica structure, it's alway been the case that when you define a fringe or contour result window, the legend levels are defined automatically.
When you're doing a project, with the umpteenth variation  of your subject, you know that you always want to use a typical range. Still the only way is to generate the fringe plot and edit the levels afterwards, after which simulate regenerates the window, which takes time.
Especially in animatred fringes, with many frames,. regenerating the animation takes an enormous amount of time.
In creo 3.0 this happens twice, once for the maximum level value after editing, once for the minimum level.
Please provide the option to define the legend levels in the definition window.
4 Comments
Dale_Rosema
23-Emerald II
Erik Haenen
You may want to vote on your own idea....
ehaenen
Done
maitken
1-Newbie
this is just another case of interface selection options not sticking in CREO3
Someone needs to review Simulate and in particular the Results section and sort this out ...
olivierlp
Community Manager
Status changed to: Archived
