Drawing, cross-section view, create arrow, we would like to set the length by "Value" not dragging.
AutoCAD is able to set the length of arrow in section by "Value" but Creo Parametrirc is not.
Creo Parametric must set it by dragging.
We can not set the same lenth of arrow size in accurate if both drawing created by AutoCAD and Creo Parametric.
We are requesting on set it value at Drawing Option.
