.UI files are mode specific for the model tree settings.
We'd like to have more control over what is stored in the .ui file and have it overlap f.e. part/sheetmetal Mode.
See the printscreen below for an example idea.
Alternatively,
perhaps it could be more specifically mentioned in this menu:
1. Describe your environment: What is your industry? What is your role in your organization? Describe your stakeholders.
Not industry specific
2. What version of Creo Parametric are you currently running?
Since Creo 6 up to 7/8/9
3. Describe the problem you are trying to solve. Please include detailed documentation such as screenshots, images or video.
The amount of .UI files to accommodate custom modeltree columns is doubled/tripled since the move from .cfg.
4. What is the use case for your organization?
To enable admins and users a more specific control over what's inside the .UI file for the modeltree.
5. What business value would your suggestion represent for your organization?
It would be a helpfull tool for Administrators, support and developers to get insight in the settings.
