Using top down design we distribute design to consuming levels with copy publish / copy geom / merge and with that have good control.
But when using patterns the intelligence of these are lost in the distribution so it's not possible to create eg. reference patterns.
As described in the attached powerpoint it's possible to distribute feature(s) which are in pattern ( so not the patteren in itself) and then pattern on recieving side but I see that as a workaround and not a solution.
