Limit pdf publish to only sheet1
In creo sheet 2 is used for creating a flat stat view of sheet metal parts (dxf export).
The pdf publish should only publish sheet 1 (sheet wityh the drawing) and not sheet 2 which only used for the dxf export of the flat state.
6 Comments
DavorGranic
You can select what pages you want to print in pdf. You can just select "current" while you are on sheet 1.
sjacks
Is there a way to make the "current" sheet selection the default?
TomU
You can save your preferred settings (including sheets selection) into a PDF profile.  Once loaded, the profile will remain active for your entire session.  You can also call the profile via a mapkey when generating PDFs.
PTCModerator
Emeritus
Status changed to: Archived
PTCModerator
Emeritus
PTCModerator
Emeritus
