Relation strings needs to recognize a line feed character so one can use a single relation in format tables requiring single line entry or multiple lines entries in title blocks.
In the same vane, tables in format files should remember the Wrap Text state when the format is inserted in the drawing. It is odd that this doesn't behave this way already.
Often, fields such as material, finish and even the title often use only one line of text and on some occasions require a second. In order to keep a tidy drawing format, a one-line text be centered in the cell. When 2 lines are required, again the nomenclature should remain centered.
Is it a bug that the Wrap Text option is not maintained with the table in Creo 2.0?
The work around is to change the cell state in the drawing. However, this can easily be overlooked if someone updates the format and doesn't know about resetting the Wrap Text of the cell.
Ultimately and obviously, the line feed option is the better option although both should be updated. With a line feed code, the user can decide exactly where the wrap should occur.
I'm not the only one who thinks this was once available. Can I get some clarification on this?
