Link Flat reps in SheetMetal Drawings
0 Kudos
Simplified reps for flat states are a great way to avoid user input errors in family tables, however it doe spresent another end user problem. Typically when making a drawing for a sheet metal part you would have the form and flat displayed for dimensioning purposes as well a sheet to send the dxf in its flat state. The problem I see is that now you have to go and replace the rep on each sheet. this causes another end user step that can lead to remake parts. Before using a rep, you could replace the flat state in the drawing and it would update all versions of the flat in that drawing. Essentially I have replaced one possible user input for another. Is there a way to have the drawing replace all flat rep versions at the same time without having to make a multi-step maykey?  Thank you. Matthew
1 Comment
olivierlp
Community Manager
Status changed to: Archived
