Lock copied & pasted sketch so it acts as a block
It would be useful to be able to move a copied sketch around as if it was a single block.
Currently when you paste a sketch you are given an opportunity to move it as a block, and then future moves run the risk of deforming it if you aren't very attentive.
See below for an example of this issue. I would like to be able to dimension it from other entities without changing the existing point relations.
1 Comment
StephenW
23-Emerald II
If reselect your sketched items, then use the "rotate resize" command, it gets you back to the move/rotate/scale option.
I'm in Creo 4
