M instead of diameter sign before thread dimension.
0 Kudos
1. Automotive industry. Mechanical designer
2. Creo 7.
3. When showing the diameter of a threaded hole on a drawing, the diameter symbol is shown in front of the diameter dimension. It would be better if an M or G, ... (depending on thread type) would be shown on in front of the diameter dimension. Now the diameter symbol has to be manually replaced by an M. If you forget to change the diameter symbol in the drawing, the drawing is wrong and bad parts are made.
4. What is the use case for your organization?
5. What business value would your suggestion represent for your organization?
6 Comments
olivierlp
Community Manager
Status changed to: Clarification Needed
Thank you for publishing your idea. However, we need more information as specified in the form you partially filled out in the submission process. You may simply add a comment to your idea. What is the use case for your organization and what business value do you see? The more details and context you give to document your idea, the better. Think about ways to educate and convince other Community members to support your idea and present your case to the product management team for consideration.
Please let us know within the next two weeks.
Here are a few examples of well documented ideas:
Option to Import STEP file as Inseparable Assembly... - PTC Community
Make Shrinkwrap quality more scalable to data size... - PTC Community
Improve/fix the sheetmetal mirror feature - PTC Community
[Eztol] Rename action not synchronous in Eztol - PTC Community
Additionally, I invite you to check out this topic where PTC executives explain product managers' approach to customer ideas and input for product roadmaps.
ptc-2735238
3-Visitor
Use case:
We are a department of TE Connectivity that designs the assembly machine to produce our products. We still have to make 2D drawings for the our suppliers of components of the machines we design.
If we make a threaded hole in our models and we show the thread dimensions in our drawings,  we manually have to change the diameter symbol into an M. If we don't do it, makes a non threaded hole instead of a threaded hole. Then we have extra costs to rework the delivered parts.
If the diameter symbol would automatically be replaced by an M (for metric thread), then we would not have the risk of extra rework costs due to a human error anymore.
BenLoosli
23-Emerald II
Can this be done in the hole file by creating your own callout?
Thread Notes (ptc.com)
Doesn't the thread callout need a pitch, too?
olivierlp
Community Manager
@ptc-2735238, Any thought on @BenLoosli 's note?
ptc-2735238
3-Visitor
It can be done with Thread Notes. But I rather use dimensions instead of notes on my drawings.
For standard threads we don't mention the pitch.
olivierlp
Community Manager
Thank you for your additional comments. Based on the information you provided, we are acknowledging it as the Community management team. This is not a commitment from the Product team. Other users may comment and vote your idea up.
