As you know Creo has got a very useful tab that named annotate on 3d environment.
We can print our models with format but it's very hard to set the .frm file via pdf output.
If we can see format file on screen dynamically it can be more useful. you think- we are working on annotate tab and we will be able to see our format file on screen simultaneously and we will be able to change it.
