In Creo Parametric, to design a cylinder 2 options are avaible:
In first case, diameter dimension is obtained in sketch by double clicks on the circle (a simple click gives radius dimension)
In second case, diameter dimension is obtained in sketch by 3 clicks (line-axis-line)
For this 2 cases, in associated drawing this 2 kinds of dimensions can be showed on any view we want (front, top, right,…)
Using MBD, #Annotation Feature #Create a driven dimension the behavior should be similar
