MODEL UPDATE SAVE MODE
MODELCHECK AND MODEL UPDATE:
Add a config_init.mc parameter to set if MODEL UPDATE  should be LAUNCH when the user SAVE the model.
It is important to clean the models.
We actually use a mapkey but the user can save with > File  > Save and ModelUpdate is not use.
5 Comments
DomenicLaritz
As ModelUPDATE only is available in the interactive mode of ModelCHECK, we used following workaround, to make it available at the save mode:
We have a license for Pro/TOOLKIT. So I developed a small application, that uses the "Pre save notification event" (PRO_MDL_SAVE_PRE) to call the ModelCHECK in interactive mode (ProModelcheckExecute), which has ModelUPDATE available.
FPerez
Thanks  Domenic for the comment.
DomenicLaritz
You're welcome!
Maybe you can vote for my idea regarding ModelUPDATE too:
Disable automatic mass properties calculation when using ModelUPDATE
PTCModerator
Emeritus
olivierlp
Community Manager
Status changed to: Archived
