1.3.1 Mandatory, Nonmandatory, Guidance, and Optional Words
The words “shall” and “will” establish a mandatory requirement.
The words “should” and “may” establish a recommended practice.
The words “typical,” “example,” “for reference,” or the Latin abbreviation “e.g.” indicate suggestions given for guidance only.
The word “or” used in conjunction with a mandatory requirement or a recommended practice indicates that there are two or more options for complying with
the stated requirement or practice.
Same size sheet is only recommended. The first sheet being smaller is allowed.
The problem with this request is that the software was to insert plotter code for each sheet to setup the formatting, making the plot file generation time even longer as it has to calculate more settings to pass to the plotter.
