Machining Features - Feature flag text editor should support special characters
The text editor used to modify feature flags for machining features should support the full range of special characters currently available in the Annotation text editor.
This would allow you to create feature flag text that can be used in an engineering drawing.
Examples of special characters that should be made available include   Diameter, Depth, Counterbore, Countersink, Degree
2 Comments
DanAdler
This is available.  You just have to go to a regular text editor in Annotation first to figure out what the callout is for each specific symbol.  For instance the callout for the depth symbol is <Depth> or <Depth2> depending on which depth symbol you want.  My threaded hole callout is... <nominal-diameter-text>-<TPI> X <Depth2><length>
PTCModerator
Emeritus
Status changed to: Archived
