Machining: default setting for Diameter Tol on a Counterbored Through Hole should not be hardcoded to H13
0 Kudos
When creating a Counterbored Through Hole using the Machining module, it should be made possible to set a different standard value than H13 (click on "Show T&Q" to see this) for the Diameter Tolerance. This could be managed for example by introducing a suitable setting in the ma_customize file.
1 Comment
PTCModerator
Emeritus
Status changed to: Archived
