It is standard functionality that, for example, in the menu "Rectangle" if "Slant" was the last selected tool then "Slant" appears at the top of the menu for the next selection.
In the Machining menu this is not the case. Whichever tool was selected last (for example "Countersunk through hole"), this tool is not at the top of the menu for the next selection.
The Machining menu should work in the same manner as the standard functionality and offer the last selected tool at the top of the menu.
