The PTC Community email address has changed to community-mailer@ptc.com. Learn more.
Maintain Background Color During Print Preview
Maintain the currently active drawing background settings when entering print preview mode.  Don't switch to white!
From CS184887
9 Comments
StephenW
23-Emerald II
Wow, I can't believe something like this needed a product idea to get implemented. The didn't say it but the dreaded "intended functionality" comes to mind. We intended to make it non-functional.
BobSchwerdlin
3-Visitor
It worked perfectly fine in Creo 2.  Why did they have to screw it up?
I am struggling with the exact same issue.  I also run 2-D and 3-D with a black background.  I've been using Pro/E since version 17 in UNIX and this is the first time I have actually seen the print routine broken.  To say that it now sucks, would be an understatement.  I'm EXTREMELY disappointed with this build.
BobSchwerdlin
3-Visitor
"To say that it now ssssucks, would be an understatement.
TomU
santinou
Just moved on to Creo3. Can't get the pcf's I was using with creo2 to work. Meaning no pen table files I had set up either. What a fiasco. Out of all things they had to go and mess with the print routines.
And this preview sucks big time. Can't see anything.
Way to go PTC!!
BobSchwerdlin
3-Visitor
I also notice that I now have to select "custom scale" and set is to 94% before sending my "D" size print which I'm printing on a "B" size paper.  This was NEVER an issue before Creo3.0
TomU
Looks like we're going to have to wait a little longer.  Appears to have been pushed back from M070 to M090.
https://support.ptc.com/appserver/cs/view/solution.jsp?&n=CS197191
http://support.ptc.com/cs/product_calendar/PTC_Product_Calendar.htm
PTCModerator
Emeritus
olivierlp
Community Manager
Status changed to: Archived
