If you insert de Ø symbol in a Creo Parametric text parameter and designate it, Windchill will not recognize it !
You will have a "n"
PTC support tells us to not use de Text Symbol palette but copy/paste the Ø from Word
Please change this palette in Creo Parametric to make the symbols compatible with Windchill !
