In Creo Parametric linetypes (.lsl) are only be loaded when located in working directory.
If you want to create company wide linetypes it's very complicating to manage.
For materials, frames, tables, color and so on, there is a config entry for the path of it.
Please provide a config entry for a path where linetypes can be located.
This will make it much more easy do administer it.
