Make ModelCheck validate if internal & external threads fit together by size and type
Dear Creo Team,
let's add a new check for Modelcheck: do the threads of schrew and tapped hole fit together?
This check would return an error when detecting screws of M5 built into holes with internal M4 threads, for example.
That would make validating designs much faster and easier, especially on changes. In this case, often the change task is done by another person that did not first create the assembly, and all screws and internal threads need to be checked manually. Manual checks take time and are prone to errors.
greetings
1 Comment
Alexandrite
