Make Paste Special / Advanced Reference Configuration the Default for Copy / PAste
The defaulty copy / paste function is limited while copy / paste special advanced reference configuration is verypowerful.  I'd like to make the latter the default paste, the default paste special or at least have configuration options to allow the user to set the default choices when doing a paste special.
5 Comments
Dale_Rosema
23-Emerald II
Doug, you should vote for your own idea.
dgschaefer
Silly me, I figured if I created it I had voted for it. Though I registered a long time ago, I haven't been active around here until recently so I don't quiote yet have the lay of the land.
rsobecki
I wish to have parameters in config.pro to be able to set every defaults
TomU
Yes!  If you're already hitting Ctrl-C, it sure we be nice to hit Ctrl-V instead of having to locate the paste special button.
PTCModerator
Emeritus
Status changed to: Archived
