we would like to use the piping and cabling axtension, but found out that it is really cumbersome to get it to work.
We can barely check in a cabling assembly into Windchill.
That seems to be due to having modelcheck gatekeeper enabled. That is the only way for us to keep up the quality of our cad models.
But it seems necessary to run Modelcheck in another special recursive mode to get it working at all for cabling assemblies. On the opposite we have set up gatekeeper to require Modelcheck regenerate explicit since that is the only mode that catches all errors.
Please make the piping and cabling assembly module work well with modelcheck gatekeeper, regardless of its configuration.
many thanks
