Make a bidirectional path for information between Schematics and Parametric.
0 Kudos
The present (and has always been the case) status is that you create a design in Schematics and then it is thrown over a one way wall to Parametric for routing.
Schematics has no way of being given (other than manual exports and imports of custom reports) the length of fibers or if a connection has been changed so that the schematic and wiring diagram are correct.
It would help to have Parametric able to make the changes in the XML transfer file and let Schematics read it to determine the differences.
1 Comment
Alexandrite
