Make an Integration Kit function that allows to load a model based on number and version from Windchill
Currently, within the Windchill/Modeling integration, there's only the functions sd-uwgm-element-exists and sd-uwgm-element-load.
These functions accept only a filename.
Because of this, these functions always load the latest version of your model in Modeling, the latest version you have access to more precisely.
It could be handy if you could specify an exact model, by having a function that can accept Model Number and Model Revision (and optional Iteration).
2 Comments
MaxR.Kublin
In the CREO world the only load rule is "highest version".
Presumably that is the reason why sd-uwgm-element-load only accepts a filename and no additonal arguments.
olivierlp
Community Manager
Status changed to: Archived
