For current functionality, when start Creo Parametric, It will upload config.pro/config.sup file from local disk, with different order from multiple places. The drawing option file is specified by drawing_setup_file option. To know about all of these configuration settings, it takes a long time to learn and remember these for junior users. Sometimes user make mistaken since they start Creo Parametric by different shortcut and don't upload the related configuration file.
I think PTC should change this behavior the same as other generic software. Make config.pro and drawing option files embeded in Creo Parametric instead of uloading from local disk each times , which will make our engineers work more easy. Spend less time doing configuration.
