Make coordinate systems easier to pick
Currently, coordinate systems are impossible to select unless you pick directly on some mysterious, unknown sweet spot.
Please make coordinate systems easier to pick by increasing the area for this elusive sweet spot or providing a window selection, which would actually enhance many other selection operations as well.
3 Comments
StephenW
23-Emerald I
The secret spot is the TAG. If you have the TAG displayed, simply select on the TAG, ie CS0. The hard one is if the TAG is not displayed, you have to select where the TAG should be, that's always interesting!!!.  You can turn the TAGs on and off in the config.pro under display_coord_sys_tags option.
dhermosillo
Thanks for the tip!
PTCModerator
Emeritus
Status changed to: Archived
