The PTC Community email address has changed to community-mailer@ptc.com. Learn more.
Make dual dimension position value ("to right" or "below") available as drawing config option
Select to enlarge:
According https://www.ptc.com/appserver/cs/view/solution.jsp?n=CS122400 it is currently not possible to configure this value.
2 Comments
PTCModerator
Emeritus
Mfridman
Status changed to: Delivered
Hi all,
This functionality was delivered with Creo 7.0.5.0 and Creo 8.0.1.0
you  can define the default position of dual dimensions using the following config.pro option: "default_dual_dim_position" and using one of the values: below/right
this option will be applied only for newly created dimensions
