Make it possible to select the "boundary" instead of the "region" when using Sketch region option
1. Describe your environment: What is your industry? What is your role in your organization? Describe your stakeholders.
Any industry using Sketches in Creo Parametric
2. What version of Creo Parametric are you currently running?
Creo Parametric 8.0 and 9.0
3. Describe the problem you are trying to solve. Please include detailed documentation such as screenshots, images or video.
When using "Sketch Region" to extrude a portion of a sketch, it would be more productive when it is possible to select the boundary of a sketch instead of selecting different regions. For example (see screenshots) when extruding the sketch in the picture as a full solid body, in the current Creo version(s) the designer needs to select the three seperate regions or areas. If it would be possible to select the boundary of the sketch, then the selection would be made in one click (see second screenshot).
4. What is the use case for your organization?
Productivity, better workflow
5. What business value would your suggestion represent for your organization?
1 Comment
olivierlp
Community Manager
Thank you @Philip_Olieux for your idea. Based on the information you provided, we are acknowledging it as the Community management team. This is not a commitment from the Product team. Other users may comment and vote your idea up.
Can you expand on the business value that your idea would have on your organization?
