Make it possible to set a default parmeter filter for each environment
According this article there is a possibility to add a custom paramter list filter. Here you can for example filter out parameters that are not changable for a user (like the parameters that has "Windchill" as a source.
The problem is that in the xml there is only one line for the default so you can set only a default for one environment. If you set it to the part environment then there is no default set for the assembly or drawing environment.
