Editing Creo Pattern Tables in Excel should be as easy as editing Creo Family Tables in Excel.
There is a config option "part_table_editor=excel" that can make editing a pattern table easier than Pro/Table (the default editor) or a text editor like notepad. However, this config option simply sends the default .PTB file to Excel. Now when you try to save any changes to the .PTB file, Excel will offer you several options to save this file in another location or another format (.XLSX) instead of just saving back to the .PTB file in your working directory. If you have successfully chosen the correct option to save the file (see examples below), you next have to close Excel. Excel will prompt you AGAIN to save the file (even though you just did)!
If Creo would simply start the process of editing the pattern table by using a .XLS file, Excel would have no concerns about what format to save to. Note that pressing the “Edit in Excel” button in a Family Table does exactly that (opens a .XLS file).
See below for examples.
How editing a pattern table works today (in PTC Creo Parametric 4.0 F000 and Excel 2016)
If you failed to select the correct options above you will end up making changes that don't save, or create extra Excel files on your hard drive that you don't need.
How saving a pattern table should work! (Using the current Family Table function as an example) This is the proposed product idea.
I frequently get users complaining that they have wasted a significant period of time attempting to save changes to the file in the right format and location to keep the changes.
