Make possible to use the Mirror tool inside the Import Data Doctor
If the imported part is symmetrical and the import error occurs on one side only, using the mirror can save a lot of time by deleting the wrong side and mirroring the correct one.
Currently it is not possible to mirror surfaces inside the Import Data Doctor.
To mirror a surface, you need to create a Mirror feature after the Import Feature and then use the Collapse tool to insert the new surfaces into the Import Feature.
It would be better to perform this operation inside the IDD, without going in and out of the Import Feature.
