Are assemblies are 10s of thousands of components and many indentures deep. Default explode status is "exploded" for all... which is quite useless (should be "unexploded"). Anyway, there is not good way to keep the explodes states of newly added components (at any indenture) cleaned-up. Need to be able to select "ctrl F" and then get a list of all components whose explode status=unexploded (or exploded)... so that only those can get toggled.
