Make the default value for "Insert" column of "Other Outlines List" is "YES" when importing an emn file in "ECAD Input - Assembly" by adding a config.pro option.
https://www.ptc.com/appserver/cs/view/case_solution.jsp?n=CS152995&lang=en
