The PTC Community email address has changed to community-mailer@ptc.com. Learn more.
Make the use of the TAB button more convenient
1. Describe your environment: What is your industry? What is your role in your organization? Describe your stakeholders.
Construction, engineer and admin
2. What version of Creo Parametric are you currently running?
7.0.5.0
3. Describe the problem you are trying to solve. Please include detailed documentation such as screenshots, images or video.
When you are in a certain data field and press the tab button on your keyboard, you go to the next field. The order of this fields are in a lot of cases not logically or on order.
For example when you want to create a reference dimension and want to place "(" in the prefix and place ")" in the suffix you click on the Prefix field (so you moved your hand from the mouse to the keyboard) type the "(" and now want to go to the Suffix field it is logically that when pressing tab you go to the next field and that is the Suffix field, but instead you go to the "Dimension Text" field.tab_order_creo.jpg
4. What is the use case for your organization?
More efficient use of the keyboard
5. What business value would your suggestion represent for your organization?
Faster engineering
2 Comments
olivierlp
Community Manager
Thank you for your idea and the information provided.
olivierlp
Community Manager
