It's a great Idea transfer this THICK to two lines reference (in my opnion) is better because it's clearer to see and understood. There is a work around using SUFIX, but we lost the command to change the value with double click. Im getting this one with Creo 4 into Sheetmetal module. If I click on measure I can see on Dimension tab an enable option on left side instead of able it as original THICK. (Attached)
Should be interesting if was possible transfer the original THICK option to other measure. Thanks,
