Manage easily the display of "Thick" dimensions (Shell or Thicken sketch)
"Thick" dimensions (Shell or Thicken sketch) are never good enough to indicate the thickness in drawings.
I suggest a “classic” dimension that could be moved by an “Edit Attachment”.
2 Comments
wbgouveia
3-Visitor
It's a great Idea transfer this THICK to two lines reference (in my opnion) is better because it's clearer to see and understood. There is a work around using SUFIX, but we lost the command to change the value with double click.
Im getting this one with Creo 4 into Sheetmetal module. If I click on measure I can see on Dimension tab an enable option on left side instead of able it as original THICK. (Attached)SUGESTION.PNG
Should be interesting if was possible transfer the original THICK option to other measure.
Wellington
PTCModerator
Emeritus
